Etcher's Paradise - Release Announcements
Started by madbean, February 14, 2016, 08:34:19 AM
Deadringer JR.
(from a suggestion by Playpunk)
This is the drive side only of the Deadringer2. Some changes were made to the design. The input buffer was dropped and the clipping transistors were changed from IRF510 to 2n7000 (both due to space limitations). The rotary switch for the clipping frequency was changed to a pot a la the Timmy (although the direction was changed so turning it up increases bass rather than decreases it so it works similar to the tone knob). I pushed this one ahead of the other planned releases because it is a good "essential" project and probably the one I will do the full tutorial on (starting that next week).
02.22.16
Narosla
- Based on the Xotic EP Booster
Holy Roller
- Based on the Bajaman LA2A Optical Limiter
Also - the PNP Photoshop file contains just the silk screen side of the boards (as a layer) since this was requested.
alparent
Quote from: madbean on February 22, 2016, 07:36:19 AM
Thanks a lot for that :)
I'm French.......sorry for my bad Englishhhhhhh.
stevie1556
Woohoo! More! Yay!
That booster looks like it would be a quick and easy one to add to the collection.
Sent from my SM-G928F using Tapatalk
02.27.16
Time for some classics
Cosmopolitan
- Based on the Skreddy Screwdriver
Zombii
- Based on the ZVex Fuzz Factory
Sunking
- Based on the Klon Siberia
Zygote
- Based on the Fulltone '69
alparent
Crap! Not new ones again.  >:(
Just kidding, keep them coming.
When I look at my day, I'm amazed that you even have time to do this.
Do you have a wife and kids?
Boneyard
- Based on the Carl Martin Plexitone
Pipsqweek
- Based on the Dan Armstrong Green Ringer
Double Flush
- Based on the Bajaman Trembulator
Snarkdoodle
- Based on the Way Huge Red Llama
Turnabout
- Based on the JHS Andy Timmons Sig.
diablochris6
Quote from: madbean on March 28, 2016, 09:26:46 AM
03.28.16
Turnabout
It is fair play, after all.
rosettastoned
thanks for this man, could you upload the first mudbunny PCB?, i etched a few years ago and want it to modify it.
regards.
Darkside
- Based on the Cornish G2. This is a true-bypass version fitted for the 125B w/ top mounted jacks.
Interesting I'd always heard the g2 was a more straightforward muff copy. I didn't realize there is an extra gain stage after the tone control. I need to start etching.
chuckd666
Isn't the extra stage at the front of the circuit?
