Etcher's Paradise - Release Announcements
Started by madbean, February 14, 2016, 08:34:19 AM
Sea Urchin
- Based on the Mad Professor Deep Blue Delay
2019 version with some additional mods
Quote from: DFX on September 01, 2019, 10:25:54 AM
from my experience with this circuit ive had to put a 100k resistor from the output to ground to avoid switch pop, noticed the schematic doesn't have this.
Pulldown at the output is contained via the volume trimmer.
Been a very long time since there's been an EP release. Here's a simple overdrive I worked up for a DIYSB challenge. Very easy to build. Or, even breadboard (my experience so far with the circuit).
Chaod (CheapAssOverdrive)
Under the Overdrive section on the Etcher's Paradise page: https://www.madbeanpedals.com/EP/
Zip: https://www.madbeanpedals.com/EP/downloads/overdrive/Choad.zip
Schematic:
So many possibilities. Interesting...No tone pot, I guess you can adjust C6 to taste?
Quote from: jimilee on February 23, 2022, 05:48:56 PM
C4 will have the most effect on tone roll off. C3 and C6 will have the most effect on clipping frequency threshold and total low end (resp).
I do plan on working up a variation for bass on this at some point.
Quote from: madbean on February 23, 2022, 05:53:02 PM
I see, my brain was thinking the loop in 1C1B. Thank you sir.
One more new Ep project: the Maglev. Based on the Keeley Magnetic Echo. Lots of optional mods included.
Maglev
Under the Delay section on the Etcher's Paradise page: https://www.madbeanpedals.com/EP/
Schem: https://www.madbeanpedals.com/EP/schematics/Maglev.gif
Zip: https://www.madbeanpedals.com/EP/downloads/delay/Maglev.zip
New version of the CaveDweller that uses dynamic modulation!
Cave Dweller 2022
Schem: https://www.madbeanpedals.com/EP/schematics/CaveDweller2022.gif
Zip: https://www.madbeanpedals.com/EP/downloads/delay/CaveDweller2022.zip
Brief demo: [soundcloud]https://soundcloud.com/madbeanpedals/cavedweller2022-test[/soundcloud]
What a great guitar sound.  Is that the Danno?  It veers into almost Chet Atkins electric classical territory.
zombie_rock123
That demo sounds awesome! The modulation particularly sounds great - sorry if it's been covered in another thread but will that be incorporated in one of the new PT2399 I noticed on the Projects page?
Quote from: gordo on March 19, 2022, 08:28:25 AM
TY. It is the Dano. Middle position, Drop D. I am really in love with that guitar!
Quote from: zombie_rock123 on March 19, 2022, 08:32:07 AM
The new mbp project (Degenerator) uses a totally different method for envelope driven modulation. It does require a few more parts but it's really sweet sounding. One small advantage is that it does not require an additional switch to turn off the modulation. So, there's that. But, both a great projects. I've still got the CD2022 on my big breadboard.
Man, I really like the cave dweller, I need to get on that one:
benny_profane
How is that dynamic modulation in the EP CaveDweller working? I feel like I'm missing something obvious, but it's not apparent to me.
mplaughlin
Hi.
I built the original Cave Dweller and skipped the Cave Dweller 2015, so I was really happy to see the new 2022 configuration. I hope you don't mind, but I've converted the schematic into a Vero layout for my own nefarious purposes, even though I was doubtful about pushing the voltage limit on the PT2399 above 5v. It works, though.
After building I thought it was a bit dark, so decided to use the various suggestions (change the 100K modulation resistor to 47K, change the cap in the op-amp across pins 13/14 of the PT2399 to 2n2, remove the 22n to ground for brighter repeats) to brighten it up, and I quite like it.
The MPF102's can be hard to source so I was thinking, since it's essentially a unity-buffer in a sort of cathode-follower configuration, the circuit could probably be reconfigured to use a MOSFET (BS170, say) instead, which is a LOT easier to source, but I haven't built that version yet because the pinouts are different and there's another resistor from gate to +9v to add, etc. I've got a Vero for that, too, though, if anyone wants to try it.
If it's OK, @madbean, I can post the Vero layouts, but I don't want to dilute your great work.
