Transistor hfe doubler?
Started by Matt, February 19, 2016, 08:08:09 PM
Matt
Matt
zombie_rock123
Never seen that before, but very interesting. I usually go for Darlington pairs where I need the higher HFEs and all I have to hand is low gain Ge. Definitely worth a breadboard!
I think it should work. But usually, increasing hFE also increases leakage (and usually also noise floor).
I did some testing with very low gain Ge trannies (like 10 - 30) in darlington pairs, and while it did work, it sounded like garbage because of the amplified leakage.
zombie_rock123
Culturejam, were your darlingtons using Russian transistors? Ive always had great results with them but now I want to revisit and make sure I wasnt hearing things :-\
kgull
A Sziklai pair is another interesting topology if you're looking to experiment :D
Yeah, Sziklai pair works about the same. The classic model has a 1K-ish resistor from collector to base of the PNP to stabilize things, but it works without it as well. At least for fuzz circuits.
Matt
Lots to try out for sure. Thanks for the input. I have some Russian ge s laying around.
Matt
