I feel really stupid but what is this?
Started by chezits, February 19, 2016, 07:15:25 PM
chezits
This is my first build and i can figure out what this is. I know its a pot but im not sure what kind
Looks like a potentiometer to me. 2MB 9mm or 16mm. Solder lug or PCB mount.
Zigcat
Very valid question, not stupid at all!
B=Linear
A=Audio (Logarithmic or Log)
C=Reverse audio
W=whacko (ok, I just made that one up. It's a strange taper most known to tube-screamer tone pots)
Zigcat
I'd use a 5mb, though. It has more storage capabilities. :)
benlanc
Quote from: gordo on February 19, 2016, 09:38:56 PM
W-taper pots generally have a notch at the midway point too. The taper is reverse log to 50%, then log from there to 100% IIRC
daleykd
I've had a hard time finding the B2M pots.  I wonder (for cost sake) if a B1M would work instead.
Quote from: daleykd on February 24, 2016, 11:06:34 AM
If you look at the pic in the original post, you'll get your answer  ;D
daleykd
Quote from: m-Kresol on February 24, 2016, 12:27:13 PM
God, I'm an idiot.  Don't mind me.
Quote from: daleykd on March 15, 2016, 06:10:59 AM
I like to blame it on lack of coffee. :]
dbp512
By any chance is this for the analog bit crusher? If it is, a 1 meg pot is fine, perhaps better as I never use more than a third of the rotation with the stock 2M. I know it says as much in the picture, but in my experience the extended range isn't worth the price of shipping the necessary pot.
"you truly are a transistor tickler, what with the application of germanium ointment to sensitive fuzzy areas. :)" - playpunk
