Total Recall voltages
Started by Jebus, April 07, 2016, 04:55:22 AM
Jebus
Hello!
I finally got my Total Recall wired up and I'm bit confused with the voltages. I'm using the recommended EHX power supply. It reads about -31V (no load). I plugged it in and measured the voltage output from the LM7915 and it reads -18,3V. That feels way too high to me, but I cant figure out whats wrong.
Input of the regulator is about -29,6V and the regulator is grounded properly. Only thing I can think of is a bad regulator, but I don't have another one to test with. Any other ideas? :-\
Measure something else, like another known working pedal with a power supply you're familiar with. Are the voltages high there, too?
Jebus
Quote from: midwayfair on April 07, 2016, 05:53:06 AM
Oh, forgot to mention: I tested it with two different multimeters and got same results. Also measured my 1Spot with both multimeters and it gave out 9,3V like always..
LaceSensor
take all the IC out
test the power and gnd at the appropriate pin on each socket
test the power at the junction of the 10r and 240r power resistors
test power either side of the zener
Jebus
Quote from: LaceSensor on April 07, 2016, 09:54:22 AM
take all the IC out
Oh, another thing I forgot to mention: no ICs attached yet.
I'll measure the voltages and report back.
Jebus
Quote from: Jebus on April 07, 2016, 11:09:35 AM
And this was the problem. I didn't know this type of regulators need a current flow through them for the output to be regulated. I started thinking this might be the case and  attached IC1. Output of the regulator went to -14,9V. Attached rest of the opamps and its still happily sitting at the same voltage. :)
Thanks for the help!
78xx and 79xx need loads, yeah :) That's tripped up a few people!
