Total Recall Biasing voltages
Started by claytushaywood, April 10, 2016, 09:14:04 PM
claytushaywood
Built the total recall, I'm getting some delay but it sounds funky like the first repeat is kinda cut off and the repeats are acting wonky.  like i only get one repeat unless I strum really hard with the feedback up  then i get infinite repeats straight into oscillation.
Spent some time trying to bias it but couldnt make much of a difference.  measured voltages but they all looked pretty good.
the only ones that were a bit off are....
IC2 pin7- is -5.8v instead of -4.7v
IC3 pin 1 is -8v instead of -6.41v
IC4 pins 5,6,7 are reading at -8.3v instead of -7.48v
anything suspicious about those numbers?
benlanc
What's your PSU and regulator voltages?
Could just need re-biasing (what you described sounds like your gain trimmers are too low), see this thread for some biasing tips (the docs aren't quite right)
