Hi Again,
Sorry, I couldn't attach the second pic to the previous question for some reason. This again has to do with Barry's PCBs, and using a breakout, specifically one of Ben's, (RullyWow), Detour boards. Please defer to the attached pics for the questions/statements below.
In the GuitarPCB build docs it states that the In/Out connections are done through the pad with the "T" next to it. The other is a ground. So I'm assuming that I would just run a hook-up from the Detour EI/EO, (orange brackets), to the "T" connections on the OMG PCB. I'd then run hook-ups from the ground and 9V, (grey and green respectively), to the G and 9V pads on the right side of the OMG PCB.
Just below P2 on the OMG PCB is D3. That's supposed to house the LED for the bypass/FX engaged. Again assuming, if I'm using the Detour, (red bracket), I'd leave this off along with the resistor placement of the CLR on the OMG PCB itself. In/Out jacks would be hooked up via the pads on the Detour marked with black brackets. Am I missing anything?
I apologize for the seemingly "basic" questions, but with every vendors hook-ups being different, and trying to use a breakout that I think would work best for me it can get confusing!
Thanks again for the help!!!
