Shoggoth Fuzz power question
Started by olejason, May 05, 2016, 06:26:31 PM
olejason
My Shoggoth Fuzz PCB has four pads... Input, LED Out, Ground, Output.  I understand how to wire I, O, G to my 1776 3PDT board but I'm not sure what the purpose of LED Out is and I'm not sure how to send 9v to the fuzz PCB.  Can I wire my DC adapter directly to the 1776 like normal and then use the 9v on the 3PDT to the +9v on the fuzz PCB?
With the gut shots I have of the Shoggoth it looks like the adapter is wired directly to the fuzz PCB.  It isn't clear where the LED Out goes or how power is transferred.  Hopefully my terminology is correct enough to make sense.
EBRAddict
If the fuzz PCB and the 3PDT use ground switching (on - off) for the LED *and* you want to use the LED on the fuzz pedal you'll probably just run the ground lead from the 3PDT LED pad to the LED OUT pad on the Fuzz.
olejason
Just wanted to confirm that this worked.  Thanks for the help!
EBRAddict
No problem, my bill is in the mail :)
