Moodring white noise
Started by Boba7, July 11, 2016, 02:09:24 PM
Boba7
#15
Hey thanks for your answer!!
I'm going on holidays tomorrow so I wont have the time to check it until a couple weeks, but I'll definitely try and report the results here.
BYP is jumped and I omitted R8.
I did try though a 100k in parallel with R9 to raise the voltage, but it didn't change the noise issue.
Do you think I should also try to lower R27 in the same time?
EDIT: Actually I did try to lower R9 and R27...
See my first post:
"- Voltages: tried to change R9 and R27 to get higher voltages on pin 3 and 5 of IC4 (resp. 3,97 and 4,04v after that), but it didn't change anything. "
But I will try again.
It's a really beautiful reverb you designed Bean
Boba7
Forgot to mention that my voltages are all back to normal after putting 100k for R9 and R27. I can't remember right now what the voltages are but they were very close or slightly above the recommended ones.
Still the white noise is present at pin 1 and pin 7 of IC4.
(and FYI I added a modulation board to the PT2399, and it didn't add any noise)
If anyone has any idea, they're still welcome, although I keep playing and loving this Moodring! :)
Boba7
Late reply to my own topic...
So I got rid of the white noise!
For some reason in my build I raised C11 to 1,5nf instead of 1nf. That made the predelay darker, and so I had to crank the tone knob pretty much all the time to get a reasonably bright reverb.
Last night I was checking my notes and so I tried to put C11 back to 1nf, et voilĂ !
There's still a tiny amount of white noise, but I think every BTDR brick reverb has some. Now it's not bothersome at all!
