Haha thanks guys. I think making these 3D models works great as a tool to see if everything is going to fit like I want (and it looks cool). I just found out that the MN3007 socket is fine and doesn't touch the underside of the jack. The jumper block on the other hand... I'll have to move that one around a little.
The biggest drawback of Sketchup is that the models that you can download are not very accurate most of the times. I used a 9mm pot from the 3D Warehouse (where you get the models), but it was pretty different from the metal shaft 9mm Alpha's I made. The last ones are very specific to the models of pots I use though. It always a good habit to check the models against the data sheets and real life components.
Sketchup has got a bit of a learning curve, but it's very intuitive. Good thing is there are countless tutorials online. I'm a bit short on time lately, so I might take me a while to write a tutorial. That's less than awesome
. If you want to read into some of the existing guides, search for EagleUp on the internet. That will get you started and there are great tutorials for installing Sketchup and EagleUp. I'm on a Mac and installing was far less easy than it is on Windows. Installing on Windows should be very convenient.
You could always try an online 3D (Eagle) board viewer (search for it). It's nowhere as extensive in the possibilities as Sketchup, but very good for a quick mockup.
