Attaching laminate to aluminum pedal box
Started by GhostofJohnToad, August 05, 2011, 03:19:13 PM
GhostofJohnToad
So I was thinking...  Stores like Home Depot, Lowe's, etc. have free samples of laminate used for counter tops.  I found a couple pieces that fit perfectly on the face of a 1590BB.  Has anyone tried this yet?  I'm curious what would work to attach the laminate to the aluminum.  Epoxy, JB-Weld, Super Glue?
stecykmi
epoxy will glue anything to anything else, usually. just make sure you clamp it or put something heavy on it so it dries nice and flat.
you could also bolt it to the enclosure, some time that looks pretty cool too.
Tpetty5
Contact cement is what you use to attach plastic laminate to a wood substrate and should also work equally well on aluminum.  Just make sure you have it lined up properly as you only get one chance.
bigmufffuzzwizz
That's a good idea. You'll have to show us if you go through with it!
cjkbug
Quote from: Tpetty5 on August 05, 2011, 04:34:34 PM
that's what I've used for attaching faceplates to boxes. a light coat on each mating surface, let dry and stick 'em together. make sure you get em straight, cuz you won't be able to pull em apart.
