offboard belton brick
Started by dbp512, December 20, 2016, 06:16:48 AM
dbp512
So I'm finally building a reverb, specifically the rub a dub deluxe with the belton 3h using vero. It has a bunch of annoying connections to both sides of the board as well as the dual gang pot. I don't want to end up with a rats nest of wires soldered onto it, so I was looking for a more elegant solution. Would something like this housing connector work? That way I could organize all the wires coming off it, and simply plug it into the brick.
http://www.taydaelectronics.com/connectors-sockets/wafer-housing-crimp-terminal/housing-connector-2-54mm-10-pins.html
"you truly are a transistor tickler, what with the application of germanium ointment to sensitive fuzzy areas. :)" - playpunk
That would work, it would probably be more headache than it's worth. Mount the brick to its own piece of vero.
dbp512
I was originally going to use vero, but when I saw that header connector I thought it might be a better idea. But I think I'll listen to you and go for vero anyway, which works well cause I won't need to wait for another part.
as long as the rat's nest fits in the box that's all that matters. You'll never see it again.
When I was testing a bunch of beltons I used a leaf socket and cut it in half and used it to "plug in" the belton brick into. I would not use it as a permanent solution but if you wanting to test and not soldier the belton it was the best option for me.
Like this one:
