Author Topic: Comp>boost no footswitch?  (Read 980 times)
thesameage
  • Electron Doctor
  • JR
    • View Profile
« on: January 19, 2017, 09:19:17 PM »
Compression and boost are the "always on" pedals on my bass board. I just ordered parts to build a 4:1 comp and a fatpants. I'm thinking of just putting them into the same enclosure with no foot switch. I have always been tempted to make pedals without a switch if they are always in but have always chickened out.
Has anyone else done this? Any regrets?
My bass board is usually: modulation>comp>boost>fuzz>sadowsky pre
AntKnee
  • Electron Doctor
  • Anthony
    • View Profile
Re: Comp>boost no footswitch?
« Reply #1 on: January 19, 2017, 09:57:31 PM »
I have considered this a couple times myself, but I reasoned that is better to have it and not need it. If you do ever need to hear or check your clean signal, you're only option is to pull the effect from your chain. Depending on your pedalboard setup, that could be a PIA.
askwho69
  • Diode Destroyer
    • View Profile
« Reply #2 on: January 20, 2017, 05:25:37 AM »
Better have switches, maybe a toggle switch is an option
sonnyboy27
  • Solder Ninja
  • Stephen
    • View Profile
    • Prentiss Effects DIY Blog
« Reply #3 on: January 20, 2017, 07:49:48 AM »
I like the toggle switch idea. You could top mount the jacks, toggle switches and power so there's only knobs on the face of the pedal. That way you can't accidentally turn anything on and off.
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #4 on: January 20, 2017, 11:06:04 AM »
I've done it, no regrets
  • Global Moderator
  • Electron Doctor
  • Jacob - SK, Canada
    • View Profile
    • JMK PCBs
« Reply #5 on: January 20, 2017, 04:19:56 PM »
The only hazard for this plan is resale. If you ever plan to move on from this effect, selling it becomes harder without a stomp switch.
Otherwise it's fine.
Willybomb
  • Electron Doctor
  • Willy, not really a bomb.
    • View Profile
    • RockStarGuitar
« Reply #6 on: January 20, 2017, 05:44:55 PM »
I agree with the toggle switch bypass at least.  Besides checking for level, there's nothing worse than bypassing the effect and finding out the clean tone is nicer...
