Fuzzrite PCB?
Started by Guava, April 08, 2021, 12:26:50 PM
Guava
Does anybody know where to find a germanium Fuzzrite pcb?  Have found several silicon versions, but no germanium.  There are a couple of vero layouts I've seen, but prefer to build with pcb's.
Betty Wont
I think you can make it on a silicon Fuzzrite pcb with a couple of component tweaks. I built my germanium Fuzzrite from this one a few years ago.
http://www.ghosteffects.co.uk/pdf/ghosteffects_lunar_incantation_pcb_guide.pdf
Zerro
Hi, you can use as npn, as pnp tranzistors, which has little different "oldie" sound. Only take care of proper pins connect. For PNP you must only swap polarity of battery and all polarized electrol. kondensers. And little lower noise, connecting some small capacity (cca 330pF) between basis and output electrode, mostly collector. Basic schema is here:
thesmokingman
I used the pedalpcb board for mine
Guava
