How do you put a pedal into commercial production?
Started by shawnee, October 24, 2017, 05:26:34 AM
shawnee
Hello guys, this question is for those who have their own small pedal companies;
I have a pedal that I have tweaked for several years now and although not an original design, I think it is somewhat different and special enough to warrant production. I have kicked the idea around for a while but don't even know where to begin. So here it goes:
1. Did you design the circuit board layout yourself or contract someone else to do it? If so, who and at what cost?
2. Who did you get to make your PCB's? What quantity and price?
3. Surface mount or through board components?
4. Who did you use for drilling boxes? Having Graphics done? Cost?
5. Overall cost to do a first run? What quantity? How do you determine a price? Was it worth it?
I understand that this is not a money making venture. I am really not interesting in producing anything but this one pedal so this is not intended to be a "start" to something bigger. It would just be awesome to know that people use something that I spent so much time trying to sound as good as it can.
The way we do it at FFX is evolving, and it's not the kind of process that you are interested in (based on your post).
But, I can answer your questions with what I would do if I were starting my own pedal company.
1) PCB Designed myself (I've done hundreds of boards)
2) Elecrow or one of the other cheap Chinese board houses. Boards are generally about $1.25-$2 each including shipping. Quantities can be very small (<10)
3) Through hole unless there is a good reason otherwise (I can explain my thinking if you want)
4) I might drill them myself because I have a decent drill and step bits. I would most likely use Mammoth or PPP to do UV printing of the graphics. If time was more important to me than money, I'd also have them drill.
5) Hard to calculate without knowing quantity, finishing specs, costed BOM for the circuit, how much work is outsourced, etc.
If you want, I could help you start analyzing costs. I've seen enough of how pickdropper does it with FFX to be able to do it on a smaller scale.
diablochris6
First question: are you planning on selling direct or through dealers/distribution?  That will play a significant role in strategy.
shawnee
Thanks for the replies and great info guys.
I would rather sell direct. Think Analogman, Paul Cochran, or Klon but wildly unsuccessful......
Also, time is important to me so I think it would be worth it to hire out as much of the process as I could. PPP would probably be my best bet to buy painted and drilled enclosures. My son is willing to help and he's a screen printer with access to everything needed at work to do graphics. He can also solder well and is willing to help me build. He also works at Music Lab in Austin so a lot of people could potentially demo the pedal with their own rig in that setting.
Quote from: shawnee on October 24, 2017, 10:12:09 AM
It might be tricky to silkscreen boxes *after* they've been drilled. I would recommend simply including the drill marks in the artwork and drilling post-screening. If you're not planning on selling many, it shouldn't be a big time-killer to drill them yourself.
I guess the question I have is how many do you plan to produce during a given period? Are you shooting for a single run of 25 or 50? Or would you rather build 10 a month?
shawnee
Great idea about using drill marks on the silk screen. I didn't want to drill at all because laying out the marks is a pain but I could drill them pre-marked.
I guess not knowing what the interest level would be I would start out with a single run. If 75% or so were sold, I could re-order and start a list for the next batch. That would keep me from constantly having to keep building if I was between batches. I'm talking best case scenario as far as interest of course.
I guess I would have to get a tax ID and deal with that aspect as well.
Ok, if you are going to sell direct, here's a reasonable process flow:
Start with a 10 build batch.  This will limit your cash exposure.  If you are feeling really adventurous, you could bump to 25.
- Order pre-printed enclosures from PPP.  Either drill yourself or have them drill.  It depends on how much free time you have an how many holes are in the box.  At low quantities, they are likely to do them by hand, so you can probably do just as good of a job.  FWIW, I would drop the coin on Hougen mini hole saws.  They are expensive, but much safer and work fantastic.  If you start with a 10 pedal build, order a second batch of enclosures once you have sold the first 5.  This will help with the lead time associated with getting the next batch.
- Order double the number of boards as the batch size of enclosures.  That way, you can build up the next batch of PCBs while waiting for the next batch of enclosures.  Stage the assembly process so it doesn't all come to a bottleneck.
- Find the break points for components.  Personally, I would go reasonably heavy on the passives 50-100 (or whatever the break is at Mouser) to keep the pricing reasonable.  At this, the costs are often reasonably competitive with Tayda (which I believe have no business in commercial builds).
- Put together a BOM of actual cost breakdowns with and without quantity breaks.  That way you have a feel for your actual costs and the trade-offs.  Add a buffer for parts handling (shipping costs usually).  Do your best to include all incidental costs.
- When you setup your artwork, make sure you have some acceptable tolerances built in.  Don't run anything internal hard to the edges.  Places like PPP are great, but aren't known for their military precision.
I am sure there's more, but that's a start.  Nothing here is the definitively *right*  way to do it, just my thoughts at the moment.
You probably don't need to worry about taxes yet unless you sell quite a few. There is some point (I think it's $600-$700) of profit that you don't have to report or pay taxes on. You only need to worry about taxes if you make more than that in 12 months.
Get cozy with guitar magazines too.  My old company Laffing Dog sent a few of our Blue Dogs out for review and the reviews were stellar, which in turn got us in the door at Chicago Music Exchange.  CME did quite well with the pedals till time/financial burdens took their toll and we dropped off the radar.  By then any momentum we had (15 minutes in the sun) was gone.
I think that anyone else that's doing or has done it before will agree that the business end of things can really ruin a great hobby.  That said, there's no reason you can't ramp up or down depending on if you're basing making a living at it or not.  In our case we were all too wrapped up in previous lives to really make a go of it.
It's a cool feeling knowing that your stuff is out there getting played though...
Don't want to be a party pooper, but in the US, if your pedal has a charge pump or anything digital in it, you'll also have to worry about FCC compliance once you go commercial (been a while since I looked into this, so I may not remember all the details accurately...).
Quote from: EBK on October 24, 2017, 05:14:41 PM
EHX got dinged, but I doubt the average small pedal company is going to draw any scrutiny from a federal agency. I see Wampler has his stuff tested, but most other mid-sized companies don't seem to be in compliance.
That's why I said you'd have to "worry" instead of "comply".  :P
The FCC is always aware of the fact that they are spending the public's money to protect the public.  If the balance of public dollars vs. public value is significantly skewed, then, yes, they will look elsewhere.
shawnee
