Source for a 500kC pot with a wah gear?
Started by drezdn, December 12, 2017, 08:52:35 AM
drezdn
There's a phaser pcb I'd like to mount in a wah treadle, but I can't find a 500kC pot with a gear. Does anyone know where I can get one, or how to add the appropriate gear to a regular 16mm pot?
There are push on wah gears for splined or 'D" 1/4" shafts. Maybe with a nice industrial strength PEC pot.
http://www.smallbear-electronics.mybigcommerce.com/racks-and-pinions-1/
Your harder task is going to be finding a 500KC pot that will "fit" in a wah shell  :-\
sjaustin
When I did this same thing (but with a vibe), I went with the Dunlop ECB024A Hot Potz Cry Baby Potentiometer – 470k. It's not quite 500k, but it was as close as I could get. I believe it's a log (A) taper, but you can wire it backwards.
ETA: I bought mine on Amazon.
Quote from: sjaustin on December 12, 2017, 11:20:40 AM
I'm pretty sure all of the Hot Potz II tapers are (B) Linear. Maybe you can use resistors to get the curve you need though.
sjaustin
Quote from: Govmnt_Lacky on December 12, 2017, 11:40:53 AMI'm pretty sure all of the Hot Potz II tapers are (B) Linear. Maybe you can use resistors to get the curve you need though.
Small Bear has them with a more detailed description, including that it is an audio taper.
Quote from: sjaustin on December 12, 2017, 11:47:43 AM
Missed that one. I don't surf SB website very often though...
