Fat Pants JR. Debugging. T1 isn't biasing?
Started by elenore19, February 10, 2018, 11:52:42 AM
blearyeyes
No you just put whatever you want into the little blue socket and close the lever Push the button and it will read out information including what pin on a Tran is in what number socket. Just use the first three holes in the socket for Trans 1 and 3 for anything with two wires.
blearyeyes
elenore19
I assume I just check the values against a data sheet or something?
Or does it literally just say "good" or "bad"?
