Author Topic: Does the Pork Barrel Invert the phase? Will it work with Buff N Blend?  (Read 1634 times)
bscur
  • Transistor Tickler
The Pork Barrel question made me curious if I could use a Buff N Blend (creates a mix knob) With the Pork Barrel. The GuitarPCB site mentioned trouble if the pedal inverts the phase. Does the Pork Barrel do this? It seems like a good pedal to add this on to.
Thanks
Re: Does the Pork Barrel Invert the phase? Will it work with Buff N Blend?
« Reply #1 on: February 24, 2018, 04:17:42 PM »
IIRC and as is usual with BOSS stuff, non inverting transistor input buffer, inverting pre-emphasis stage, inverting de-emphasis stage so no, it doesn't invert the phase :)
brucer
  • Solder Ninja
  • Bruce ... R
« Reply #2 on: February 24, 2018, 06:29:43 PM »
No idea about phase inversion, but I used a little vero blend circuit (http://tagboardeffects.blogspot.ca/2012/02/split-n-blend.html) and a capacitor switch to turn a Pork Barrel into a CE-2B.  Works great!
  • Administrator
  • Brian
    • madbeanpedals
« Reply #3 on: February 24, 2018, 07:47:16 PM »
Output and input are in phase.
blearyeyes
    • Musical Endeavors
« Reply #4 on: February 25, 2018, 12:14:28 PM »
BAM!
