Author Topic: BOSS CE1 PROJECT: MN3002 or TDA1022P: DOC UPLOADED  (Read 54902 times)
RonSound
  • Diode Destroyer
    • View Profile
Re: BOSS CE1 PROJECT: MN3002 or TDA1022P: DOC UPLOADED
« Reply #180 on: December 09, 2020, 04:02:31 PM »
I just finished my build and it worked great right off the bat.  A little noisy with battery power but not any more than I'd expect.  I added the Chorus Depth control.  The only thing I would've liked would be some way of telling whether it's in Chorus or Vibrato mode, like a bi-color LED or something.
« Last Edit: December 09, 2020, 04:04:16 PM by RonSound »
RonSound
  • Diode Destroyer
    • View Profile
« Reply #181 on: December 09, 2020, 05:43:49 PM »
I decided to try adding a bi-color LED to the circuit.  I used the unused center column on the chorus/vibrato footswitch to do the switching.  I ran a wire from the cathode pad to the center switch lug.  The common cathode of the LED goes to the other LED pad and each of the LED anodes to the top and bottom switch lugs  (top lug for chorus, bottom lug for vibrato).  I had to drop R64 down to 5k to make the LED a little brighter until I get some better bi-color ones.  It didn't seeem to affect the sound quality at all and now it glows green for chorus and red for vibrato.  Here's a quick diagram in case anyone else wants to try it.
  • Electron Doctor
    • View Profile
    • Project Website
« Reply #182 on: December 09, 2020, 07:58:59 PM »
What a great looking build.  The demo video showed off the deep capabilities but I found I needed dramamine to handle it.  The original was not at all subtle but didn't veer off into queasy territory either.
Vaxed, boosted, ready to rock...
DR_BEN
  • Diode Destroyer
    • View Profile
« Reply #183 on: December 31, 2020, 11:44:26 AM »
Bingo!
I am honored to show you me newest project. It is a copy of iconic chorus BOSS CE-1. I spend months over this project,  of course I made lots of prototypes.
Here are differences between mine project and original:
👉power supply 9V or polarization BOSS
👉substitute hard to find analogue delay line MN3002 with newer electronic circuit
👉smaller box
Ricotjuh
  • Transistor Tickler
    • View Profile
« Reply #184 on: December 31, 2020, 02:14:45 PM »
That looks good. Is this just the exact copy described earlier in the topic? Or does this differ from what has been discussed here?
Are you willing to share your experience and schematic? So that we can all learn something from it?
DR_BEN
  • Diode Destroyer
    • View Profile
« Reply #185 on: January 23, 2021, 05:13:52 AM »
Thanks! Those are oryginal schematic with equivalent (TDA1022), and mod supply section.
Sound samples:
&t=2s
Kerop
  • Diode Destroyer
    • View Profile
« Reply #186 on: August 28, 2021, 02:24:14 AM »
Hi everyone, I've finished the king of chorus v.2 but it's not working. How likely is that I have a bad/fake TDA1022P?
The pedal powers on, leds work, I can only hear the guitar but with no effect. I also notice a very low amount of distortion in the background when it's on. Wiring and soldering are right and components are correct. The 'volume' and 'rate' pots work.
Is it worth trying a new 1022P chip?
Thanks
« Last Edit: August 28, 2021, 02:28:46 AM by Kerop »
johnk
  • Diode Destroyer
    • View Profile
« Reply #187 on: August 28, 2021, 02:35:05 AM »
mine never worked either and i tried another TDA1022P chip but to no avail.
Kerop
  • Diode Destroyer
    • View Profile
« Reply #188 on: September 05, 2021, 09:24:19 PM »
Quick update on this. I bought new chips and the pedal now works!
I just had a fake Chinese version. Watch out people! The pedal sounds great though, it's a great project.
johnk
  • Diode Destroyer
    • View Profile
« Reply #189 on: September 05, 2021, 10:28:39 PM »
hmm. mine looks real. i got it from smallbear a couple of years ago. it still didn't work though.
Kerop
  • Diode Destroyer
    • View Profile
« Reply #190 on: September 06, 2021, 02:35:14 AM »
It's not easy to assemble as the spacing is not much, I had to check the wiring quite a bit, but the v.2 of the pedal I have is all correct in the end.
