Tap Tempo Kit?
Started by AllenM, March 27, 2018, 09:55:34 PM
AllenM
Anyone seen a similar tap tempo kit available in the US?
http://uk-electronic.de/onlineshop/product_info.php?products_id=3099
I like that it is more compact than the current option from diystompboxes and possibly more budget friendly.
AllenM
blearyeyes
#1
I have only tried to use one tap tempo product so I cannot speak to the one from Germany BUT the one I tried did not have a calibrate function and relied on the specs of the PT2399 which are very much NOT consistent. (I had 73 and couldn't find one that was correct) I could not get the product to function properly and the echos where not ever in synch with the LED flashing or the music tempo.  There is one project called Taprecise here on the board that uses a calibration test  to adjust to the particular PT2399 that you are using.  I heard good things. Haven't built mine yet.
