Violet Ram's Head
Started by pickdropper, June 13, 2018, 02:26:06 PM
I decided to redo the layout for my mini muff board.  I'm fairly pleased with how it turned out.  The first build i did with it is a miniature Violet Ram's Head.
Drool...
your builds are all so fantastic. That layout is very nicely done.
OCD at its finest, nice job.
sjaustin
That is stunning. Above and beyond your usual level of work!
Love the layout; it's a work of art in itself! What are you going to... do with it? 🙂
Where do you get your white PCBs fabricated?
Hot! I love the white PCB too, makes me think of nougat. (Must be hungry?)
Cool font on the enclosure, what's it called?  😊
Amazing!
Dave, have you considered starting pedal company and cashing in your talents?  ;D
Quote from: nzCdog on June 13, 2018, 08:00:08 PM
I don't remember.  I'll check when I get home.
Quote from: culturejam on June 13, 2018, 08:07:52 PM
All except the cashing in part.   ;D
storyboardist
Guy behind Effects Layouts
Absolute perfection. Screw holes even spiffy on this one.
Good lord that beautiful! So clean.
bsoncini
That might be the cleanest build I've ever seen. Maybe you're hiding a rat's nest of wires under the pcb?
playpunk
Shut it down folks. We've hit peak clean 1590a.
"my legend grows" - playpunk
Quote from: bsoncini on June 13, 2018, 10:13:55 PM
There are definitely wires underneath the PCB.  I prefer not to board mount pots in 1590a builds.
I use a lot of ribbon cable to keep it clean.  This is an older build.  It's not nearly as clean as I do it these days (I have an improved footswitch board that's cleaner).
I'll take a new photo next time I wire up a 1590a
