Top mounted jacks.... one day, I'll get it right.
Started by Willybomb, July 12, 2018, 01:12:35 PM
Yet another very awesome thing that makes me say: "Why didn't *I* think of that?"
zombie_rock123
Thats awesome and would definitely pick one up in your store
Super awesome. I love a good jig to make thing easier. This is fantastically simple.
Quote from: m-Kresol on July 13, 2018, 02:12:45 PM
I would greatly appreciate it, if you could share a template for this! I imagine, ordering this from oshpark will be very cheap and easy..
The mouse nibbles on the edge of OSHPark PCBs might screw with the registration of the template on the enclosure edges, though.
BuGG
Quote from: alanp on July 14, 2018, 01:56:07 AM
Yep.  To prevent this from being a problem these are built from three individual non-panelized PCBs.   It costs a bit more to do it this way but it gives each part a much nicer edge.
I didn't expect so many folks to be interested, let me see how many I have left and I'll get some more on the way if needed.
Willybomb
I'll definitely be getting one from you BuGG.  Unfortunately, it just means that I'll have perfectly aligned holes at the wrong end.
Update:  I cut up my spare label and filled the holes with PVA...
Quote from: EBK on July 12, 2018, 01:34:33 PM
I've used JB Weld to fill in misdrills and also to redrill an old enclosure for recycling into a new pedal.  It works pretty well.  An example:
Before repainting (I did add a bit more JB Weld to fill in some divots after I took this pic).
+1 on this. I've used this same method and it definitely works. I haven't had any problems with the JB weld "plug" cracking or falling out. It seems to be nearly as tough as the original aluminum.
Signatures are displayed at the bottom of each post or personal message. BBCode and smileys may be used in your signature.
Quote from: lars on July 14, 2018, 03:52:52 PM
What do you guys use on the back side to hold the JB Weld in place while it dries? Tape?
Quote from: culturejam on July 14, 2018, 05:31:22 PM
Gaffer's tape is what I used.  Also, I don't remember if I got this tip here or over at DIYSB, but slightly beveling the hole that you are about to plug on both sides (as if you are slightly countersinking) may give your JB Weld "coin" a bit more security.  I wouldn't call it a necessary step though.
Just as with any other template, it is made for a specific thing. My question is what if there are components or other items that interfered with the jacks or power plug? It's all well and good for guts that have plenty of clearance but, what if that is not the case? Essentially, every design would have to be produced with that template in mind.
Quote from: Govmnt_Lacky on July 14, 2018, 09:32:20 PM
Yep, and that's why standardizing around a single set of hardware placements saves a ton of time and money in a production environment.
Quote from: culturejam on July 15, 2018, 12:11:09 AM
Gotcha. So this would only be viable for those who are comercial builders then. Now I understand.
Quote from: Govmnt_Lacky on July 15, 2018, 12:13:46 AM
I think hobbyists would get some use out of it, but it does sort of limit your options. If you like to build each pedal with a totally unique setup, templates are probably not ideal.
Willybomb
If it fits into your design parameters, it'll be a massive timesaver.
In all honesty, most of my pedals use the same template as far as in/out/power goes, with variation depending on what controls are necessary.
