Autobahn aka MP Snow White autowah (Troubleshooting)
Started by brainbender, August 11, 2018, 09:51:43 PM
brainbender
Hi!
I'm having trouble with Autobahn. When I put a 78L05 in it's place, pedal sounds thin and have a pronounced envelope and high quack. Without it it seems to work ok (but just OK :D), but it has a high volume boost and it seems it triggers somewhat strange. I checked the tripple checked the values of components, checked for bad solder joints and shorts with USB microscope and everything is good. Also, i swapped more then 10 78L05's and replaced the IC's with other, but nothing is changing.
Any sugestions? Thanks! :)
Clear, up close pictures both sides of the board and off board wiring. Also, do you remember the jumpers?
brainbender
#2
My phone camera broke, so I can't post any photos. Everything with pcb is good, just as components. Weird... I can post some audio tomorrow. Offboard wiring is as always, Brian's method.
Btw. it sounds more like EHX Bassballs if that helps. :)
