Footswitches: Which one and why?
Started by Ekimneets, September 02, 2018, 06:43:52 PM
Ekimneets
This is why I love picking other people's brains. One, I've already learned a new soldering technique. Two, I pride myself on my tight builds with little, if any, extra length of wire. Never once, did I consider the need for repairs.
OMG, I've got so much to learn.
Mike
Legion of one at Black Octopus Pedalworx.
machfrequency
Quote from: somnif on September 03, 2018, 03:08:44 AM
My last couple batches have been the "Pro" 3PDT's from Mammoth. They were on sale for like 1.50 a piece so I bought a dozen. Lately I've been looking into opto/relay based set ups that use different switch types, and haven't settled on what to use for them really.
I've played with Tayda's soft touch spst stomp on my VFE builds and haven't had any trouble with it YET, but I can tell it does feel a little cheap. Thankfully given its design it will be easy to swap out if necessary (I use NASA style solder joins on them, straight wire soldered parallel to the pole piece, super easy to remove the wire that way)
Can anyone point me in the direction of an opto/relay switch seller/manufacturer?
1776 have a small PCB available to make one with a DPDT switch but It would be great to have a stand alone switch, like "The Gig Rig" OptoKick switches.
Cheers, Ben
(First contribution to this community, thanks everyone.)
I have had 3 or 4 of the DPDT momentary footswitches (PCB pin) fail on me from BLMS. Funny thing is, when they failed... they failed as latching  :o
Quote from: jimilee on September 03, 2018, 08:16:07 AM
I think he means this
Is this a woman in the pic? Wondering why "he" would be wearing such a large stoned engagement ring  ???
Quote from: machfrequency on September 04, 2018, 06:10:46 AM
Cheers, Ben
I can't find any pics of what the inside of the switches look like, but I can almost guarantee the switches themselves are momentary soft-touch with optical circuitry attached. I dug up the patent application for their "Quartermaster" board ( https://patents.google.com/patent/US20050056142A1/en?oq=US10%2f937%2c997 ) and it seems to use optical elements as muting/routing, pretty much as expected.
If you want something more compact than 1776's there is a switch-bottom sized version over at THCustoms: http://diy.thcustom.com/shop/optotronik_kit/
If you're looking for pre-assembled switches, that I'm afraid I can't help with. I have no idea where to even start looking for those.
machfrequency
Quote from: somnif on September 04, 2018, 01:47:58 PM
Cheers, Ben
Thank you friend.
I will look into it.
BryGuy
THCustoms has a lot of switching options and what is nice is he sells them in kit form. You get everything you need minus the switch. I've used the Optotronik sever times and they work well. Probably going to give one of his Uber Switches a try at some point; it's a relay/micro controller type.
If your looking for a relay bypass without a microcontroller PARASIT STUDIO sells such a pcb though I have not tried it myself.
Quote from: reddesert on September 03, 2018, 10:52:26 AM
NASA soldering standards are on the web, you can look at the inspection standards where I got this picture, http://www.sal.wisc.edu/docs/Soldering%20Basics.pdf,
or the soldering technical standards document https://nepp.nasa.gov/docuploads/06AA01BA-FC7E-4094-AE829CE371A7B05D/NASA-STD-8739.3.pdf. Few of us would literally solder everything to these standards.
A lot of good "what to look for" reference photos in that nasa document if you are concerned about your solder joints. A great reference source.
Quote from: Govmnt_Lacky on September 04, 2018, 01:29:43 PM
That pic has been around for years.  It is a woman in the pic.  It's a staged stock photo picture with somebody who clearly is not in it for their soldering experience.  ;-)
IIRC, most versions are watermarked by Shutterstock.
