PedalPCB Duo-phase
Started by DLW, October 09, 2018, 11:13:01 PM
DLW
I am getting a normal effect out of phaser A (right, component side up). Phaser B passes signal fine, but the pots have no affect on the rate or depth. The board has not been put in an enclosure yet, so the switches are not soldered in place. Would this be the cause? If not, are there specific components I should check?
Thanks,
Darin
The switches are what connect the LFO to Phaser B. So without them soldered into the circuit, you essentially have a static filter in place from that half of the board. No phasing, just a big complex fixed tone knob.
DLW
thanks! I'll drill the enclosure and solder the switches.
