How to wire this DPDT switch?
Started by DLW, December 08, 2018, 06:26:21 AM
DLW
I am getting ready to box a Deadastronaut Abductor Delay board, but I don't understand how to wire the DPDT. My first guess was to hook all three wires to one bank of the DPDT, but that faults the circuit.
The schematic is in the PDF here: https://deadastronaut.wixsite.com/effects/abductor-delay-ii
P.S. The board works fine with a text box.
Look up millennium bypass.
DLW
Thanks for the hint! There are three wires that come off of the "Footswitch" section on the board. I assume one of these wires is the "control" wire, based on the Millennium bypass. The other two could be +/- LED, i guess. That would be weird, considering there is a separate footswitch LED already wired separately.... so what are the other two wires, then?
Stomptown
Forget about the Millennium Bypass for this one. The video on his site indicates it is wired for tails (not true (or millennium) bypass). It looks like all you need to do is wire the in/out pads to the input/output jacks and footswitch pads go to one pole of the switch as you suspected.   The led is wired straight to the pcb and will not be connected to the switch.  Here is a gut shot for reference (Im pretty sure it's dead astronaut's build).
