The 1uF is because it uses a film cap instead of an electrolytic. It's more of a mojo/boutique choice (depending in where you stand on electros vs. film in the signal path).
The position of R6 relative to C7 doesn't matter in this case (before or after). It does two things - a bit of current limiting from the gain stage and setting up an LPF with C14. Why I did it before...if I had to guess I'd say it's because the Slow Loris is one of the oldest mbp projects and back when I hand-making all the PCBs the layout worked better with the parts in that order. I guess I never changed the order back it when I started doing it as a double-sided manufactured board.
In any case, if you are using the SL for bass, it would not hurt to change C7 and C9 to 4u7. This would ensure any really low subs from the bass get through.
