insulation "tubing" for transistor leads
Started by MarkL, January 19, 2019, 10:56:16 AM
MarkL
Looking at the guts of some vintage Tonebender clones out there, I see the leads are insulated by colorful tubing that doesn't look like heatshrink tubing, or like the insultion stripped from regular hookup wire.  Anybody know what this stuff is called, and where I could find some?
peterc
Hi Mark
I have used heat shrink in the past, but the non-shrinking stuff is called sleeving.
here is a link to give you some idea of what is available
https://za.rs-online.com/web/c/cables-wires/cable-accessories-ties-tools/cable-sleeves/?searchTerm=sleeving
Peter
Affiliation: bizzaraudio.com
MarkL
Thanks so much guys.  This will make it SO much easier on me than all the second-guessing wire stripping I've been doing!
Manc
I use bits of the insulation of stranded wire. Works pretty well and I get to recycle those bits of wire too short for other applications (the insulation at least).
czapa tranzystor 2
