Madbean libraries won't load into eagle
Started by mark123, April 14, 2019, 01:10:43 PM
mark123
My issue seems to be random. Sometimes I can use Madbean libraries in Eagle but sometimes I just cannot get them to work in a design. I'll add the libraries and they just don't show when I go to add a component.
This has only started happening since I updated to version 9.3. Before that it was fine. Is it just me? (I'm used to that. :D)
DLW
i find myself continuously needing to click "use all" in the library of the control panel for it to show up. I'm using 9.3 as well.
Quote from: DLW on April 15, 2019, 11:54:08 AM
Yep, you need to make sure that the dot next to the library is green for the library to be active. you can also click the dot instead of right click -> activate. Also, I disabled all the non-local libraries. There are just way too many and scrolling to the one you need is tedious, especially considering that the search function in eagle is still utterly useless.
mark123
#3
Sorry to come back to this but where do I find the "Use All"?  I'm not seeing it. Found it after posting. (Of course)
mark123
#4
Quote from: m-Kresol on April 15, 2019, 03:03:25 PM
Found it. Thanks.
