Dirt Bag Parts?
Started by tenwatt, November 01, 2011, 05:59:05 PM
Tayda has greenies...and cheap shipping.
http://www.taydaelectronics.com/servlet/StoreFront
tenwatt
#31
Are these good for the 27pF, 120pF, 150pF, and 240pF?  Also, my trimpots are about 1/4" and don't fit between the resistors.  Is there a better/smaller option.  I'm using the Cermet's from Smallbear.
Not too bright....
Quote from: tenwatt on November 28, 2011, 04:22:50 PM
Are what good?
But if they're caps then yeah... they're good. Ceramics, Film, Silver mica, just depends how much you want to spend.
The trimpot, I think the boards are sized for the Bourn 3362 type, Tayda have them - http://www.taydaelectronics.com/servlet/the-Potentiometer--fdsh--Variable-Resistors-cln-Cermet-Potentiometers-cln-3362P/Categories
tenwatt
#33
Crap...I forgot to post the link:
http://www.mouser.com/Search/ProductDetail.aspx?R=C317C270J5G5TAvirtualkey64600000virtualkey80-C317C270J5G
Also...those trimmers are exactly what I have.  They don't fit between the resistors in some spots.  The pins line up perfect they just don't lay flat on the board.  I'm being anal.
Not too bright....
The Cermets from Smallbear are 3/8" not 1/4". The 1/4" are available from Mouser or ebay. Bourns is a popular type.
Quote from: tenwatt on November 28, 2011, 04:49:41 PM
Look good, 5% tollerance, should be perfect.
Quote from: jkokura on November 28, 2011, 04:52:44 PM
Well whatd'ya know, are the Tayda ones suitable? Can't see a mention of size.
Quote from: Scruffie on November 28, 2011, 05:06:37 PM
Tayda are 3362 so yeah they be the perfect peice.
https://www.gigaheartsfx.com
instagram @gigahearts_fx
tenwatt
Didn't I read somewhere that the #1 pin on one of the ICs or BBDs had to be clipped off or something?  I can't find that in the build doc.  Am I imagining things?
Not too bright....
bigmufffuzzwizz
Quote from: tenwatt on November 29, 2011, 09:15:31 PM
I believe that's true for the LT1054 charge pump chip. IIRC, there's some info in the new Road Rage doc.
tenwatt
Ahhhh, yes.  That's what I'm remembering.  Thanx!
Not too bright....
dwstanford
Yeah, thats on the charge pump if you use e lt1054.  Dont clip the first pin off your 3005's.   ;D
Quote from: dwstanford on November 30, 2011, 01:25:18 AM
Holy crap. I literally winced when I read that.
bigmufffuzzwizz
Quote from: jubal81 on November 30, 2011, 04:01:38 AM
Yea i really held my breath...
Pro tip - dont cut pins off of ICs (!)
You might need them to troubleshoot another project which requires all pins intact, and on a rarer or more expensive / hard to source IC, I wouldnt risk mutilating it
The solution is to take a second IC socket, and remove the correlating pin from that, then insert the IC into the "trimmed" socket, then plug that into the second socket soldered on your board.
HOpe that makes sense
tenwatt
Quote from: dwstanford on November 30, 2011, 01:25:18 AMDont clip the first pin off your 3005's.   ;D
No.  I wouldn't have.  I would have modded my socket.
Not too bright....
