Polarity on BLMS thinline DC jacks?
Started by vizcities, June 06, 2019, 02:46:33 PM
vizcities
This is more a reinforcement question, but: what is the polarity on Love My Switches' generic thinline DC jacks?
https://lovemyswitches.com/thinline-2-1mm-dc-power-jack/
Looking at the Lumberg build doc elsewhere on the site, it looks like their long lug is + and short lug is -. However, the doc Lawrence provides for the cheap equivalent (that is, the version I have) is confusing, and I'm not clear if it's a 1:1 clone. My only experience wiring the jack thus far was for a Punch Amp build: going from a DIY Stompboxes thread, I wired it as noted above and ended up cooking an IC. After replacing the IC and switching to a battery pack, it was fine, but I'm now a little gunshy about using another cheap thinline. Before trying again, I just want to make absolutely sure the issue wasn't reversed polarity.
Got a multimeter handy?  Sounds like you are nervous enough to want to at least double check even if someone gives you an answer, right?  ;)
tcpoint
The long lug is positive and the short lug is negative (assuming center negative).
I've been building for 5 years or so and every time I go to wire the DC Jack, regardless of what I think I know, I still plug in the DC cable and test the pins with my DMM. I've been fooled before by being over confident.
Quote from: flanagan0718 on June 06, 2019, 11:51:09 PM
-Mike
This is what I do too.  Before soldering it to anything, plug in the power, turn it on, check the polarity with a multimeter.  Then I mark the positive lug with red marker, because I'm likely to forget about 2 minutes later.
vizcities
Quote from: EBK on June 06, 2019, 03:03:14 PM
This is indeed what I ended up doing. Thanks for reminding me - I sometimes get kind of lazy about utilizing my multimeter.
