Nom Nom R29
Started by geekmacdaddy, August 18, 2019, 09:35:10 PM
geekmacdaddy
Greetings.
Can't seem to find the value of R29 (it was an addition back in the day). Any help is appreciate.
Geek
geekmacdaddy
Is it ok to leave it without a jumper if I don't want pulsing LED?
thanks
woolie
Quote from: geekmacdaddy on August 18, 2019, 09:35:10 PM
Greetings.
Geek
From the docs:
There are two ways you can use an LED indicator for the Speed control.
Method 1 – Make R29 a 1k resistor. Wire the "LS" pad to the anode of a 3 or 5mm diffused LED.
Wire the cathode of that LED to ground. This method will show a square wave output so it will blink
on and off.
Method 2 – Make R29 a 1M resistor. Wire the "LS" pad to the circuit shown below. This will give the
LED some ramp up and down on its illumination so it is not quite so "square".
Sent from my iPad using Tapatalk Pro
geekmacdaddy
Thanks for the reply, saw that. So I HAVE to use R29?
No. Only if you want an LED indicator for your speed. It has no effect otherwise.
geekmacdaddy
