Moodring output problems
Started by jolly1423, August 31, 2019, 01:50:10 PM
jolly1423
I have my moodring all put together and I have tested it wired non- true bypass and true bypass and it has really low output both when engaged and bypassed in the non true bypass mode. It's like not all the guitar signal is getting through. The verb controls all seem to work. I've been re-flowing all the connections to no avail. My IC readings are all within .2v of where they should be EXCEPT I'm getting .002v on leg 2 of IC2 and 2.25v on leg 5 of IC4. Also, the status led wired to the pcb isn't lighting (I checked the LED and it's good).
jolly1423
I found the problem! A 470k where there should have been a 470r.
*Face palm*
diablochris6
That would do it! Happens to everybody at least 10 times.
