ProphecySoundSystems Infinitephase / AlanP HeavyWater.v0.2
Started by LaceSensor, August 31, 2019, 12:05:53 PM
That thing is hellacious.
digi2t
Validation build of the DEFX Definitphase is complete. Many thanks to Mike Both (again!) on this build, he fed me a ton of info. This is a fully loaded build, complete with;
- Sample/Hold
- Stereo output
- Footswitch LFO rate doubler
- Footswitch 4/8 stage select
- Expression pedal input jacks for Rate, Depth, and Range.
- Expression pedal input jack for Phase Center, which allows for direct phase control
The only major change we've made is to replace the quad set of red LED's for the LDR's, with a single 10mm green LED. We stole that page from the Spaceman phaser. Hence the name "Definitphase", 'cuz it'll be the last phaser you'll ever need. Needless to say, it sounds awesome.  :)
http://i.imgur.com/JvCB0mr.gifv
There were some minor fixes required on this (initial) set of boards, which corrected to get it operational. The order for the new corrected boards will be going out, and we should have them in a few weeks.
That is so grandly amazing :D The extra PCB is well worth the extra options!
Are these boards available?  I looked on the Dead End FX site & didn't see them.
digi2t
Quote from: alanp on December 29, 2019, 06:44:22 AM
Thanks! The main purpose of the stacked boards is first and foremost noise control. When I originally did this on vero, I was getting a fairly bad LFO tick in the audio. Eventually, I managed to squelch it with a strategically placed cap. When Phil and I set to building a board set for this, we set out to keep the audio as far away from the LFO as possible, hence the dual boards. We find this method to be the most effective way to prevent LFO bleed. Everything LFO related on one board, everything audio on the other. On my vero, I added the S/H post build, on a separate board, so I didn't have any noise bleed. If you look at gut shots of an original unit, the S/H is on a separate board, and jumpered in. But, this board set, the S/H was designed onboard, and close enough to the audio that we were getting the 4093 ticking bleeding in. Thankfully, an extra cap on the output to the S/H rate LED, as well as a subtle reroute solved that. It's dead quiet.
Quote from: bcalla on December 29, 2019, 02:52:46 PM
Read the last line of my post.  ;)
The last phaser I'll ever need? Challenge accepted.
skyled
Quote from: jimilee on December 29, 2019, 03:36:51 PM
You'll need to get 2 of them so you can have an Infinite-Biphase setup.
