Author Topic: 9mm pots withoug threading  (Read 476 times)
pgodfrin
  • Transistor Tickler
    • View Profile
« on: November 08, 2019, 06:46:39 AM »
Greetings,
Any suggestions on how to mount a 9mm pot that has no threads to an enclosure?
phil
  • Electron Doctor
  • Eric K.
    • View Profile
Re: 9mm pots withoug threading
« Reply #1 on: November 08, 2019, 07:19:31 AM »
Mount it to a board inside the enclosure.
Then, you can mount the board however you like.  Some JB Weld and spacers made out of miscellaneous junk hardware would work if it is a one off build.
pgodfrin
    • View Profile
« Reply #2 on: November 10, 2019, 07:47:15 AM »
Thanks, it did get lost. That's a good idea! I can't exactly visualize it, but it still involves glue, albeit jb weld is stronger than hot glue. But I suppose it's fair to say the pedal is a one off - so wth. I presume the idea for these pots is the pcb is mounted somehow holding the pot in place...
