Boss fz-2 owner question
Started by imjonwain, December 13, 2019, 02:45:28 AM
BuGG
Quote from: imjonwain on December 29, 2019, 12:46:23 AM
Netnnk is going through his original pedal and I am drawing up a schematic of the OEM pedal with ref designaters and part numbers that match the BOSS ones so there will be a correct full schematic online soonish.
The Boss service manual is available.
imjonwain
From Boss or just floating around?  I tried searching quite a bit.
"I'm not sure what "serious design flaws" you see. Does it explode or poison your dog?" - PRR
imjonwain
Correct and Verified Boss FZ-2 schematic.  I have this working using basically jellybeans too.
JackSkellington
Great! ;)
Excuse me, what do you mean with this? «I have this working using basically jellybeans too.» ???
Quote from: JackSkellington on January 16, 2020, 08:58:27 AM
Great! ;)
"Jellybean" is slang for "any cheap transistor you have at hand", so things like the 2N3904, 2N5088, 2N2222, etc etc etc
imjonwain
yup!
What I have it working with
Q1,Q2.Q11: 2n3904
Q3,Q4,Q8: J113
Q5,Q6: 2n5088
Q12,Q13,Q14: 2n3903
Q7,Q9,Q10: 2n5485
Q15: 2n3906
IC1, IC2: 4558
I honestly used things I had around and didn't order anything special.
Q9, Q10, Q15 can be sensitive.
Q1,Q2,Q5,Q6,Q11,Q12,Q13,Q14: 2n3904 or whatever would probably work fine for all them.
Mind your wiring or it will oscillate wildly.
aion
If anyone's interested, I did a PCB for the complete FZ-2 circuit (including discrete pseudo-opamp boost) based on imjonwain's schematic -
https://aionfx.com/project/hypercube-fuzz-distortion/
