Wavelord 1P8T from Smallbear NOT continuous
Started by dawson, December 17, 2019, 02:05:22 PM
dawson
Greetings, fellow noise enthusiasts!
This post is regarding Smallbear's 1P8T enclosed miniature rotary switches:
http://smallbear-electronics.mybigcommerce.com/rotary-switch-miniature-1p8t/
I've just received a couple of these in the mail, however the ones that I got do NOT turn continuously from 8-1 as stated in the MBP Wavelord build document.  Do I need to alter the switch in order for it to function continuously?  Did I buy the wrong thing?  Do I need to crank the poor guy around real-good to make it submit?
Any input would be appreciated!
Criticism is encouraged: constructive, or otherwise.
Did you remove the washer that stops it from turning?
Quote from: jimilee on December 17, 2019, 02:54:29 PM
These don't have a washer, AFAIK. The ones I have are continuous but I did not get them from smallbear - actually, I requested they carry these last year so I assumed they were the same ones. However, it should be fine. They appear to be exactly the same otherwise. The order of the waveforms won't change.
benny_profane
Quote from: madbean on December 17, 2019, 04:22:44 PM
Where did you get the continuous rotaries?
dawson
Thank you all for your input- I believe that the switch I got will work perfectly and sound great, however, the knowledge that a continuous rotary switch exists and I haven't got one fills me with a searing jealousy!
At the end of the day though, if there's anyone who deserves to have cooler switches than everyone else..I believe it's BEAN.
Quote from: benny_profane on December 17, 2019, 05:25:43 PM
https://www.adafruit.com/product/2925
benny_profane
Quote from: madbean on December 17, 2019, 05:56:55 PM
Very cool. Thanks! Did yours come with the quarter like the picture?
dawson
To wrap up this thread, here's the layout of the waveforms for anyone who's got a rotary switch like mine:
Just like the build report says: "When attaching your knob to the switch, first rotate it" completely counter-clockwise "then screw the knob in facing straight up."
My WaveLord build report here:
https://www.madbeanpedals.com/forum/index.php?topic=30572.msg295016;boardseen#new
I should add a note in the build doc about the different switches. I don't want anyone putting artwork with the different waveforms only to have them not line up. In fact, I did this very thing when I first prototyped it (but because I wasn't paying attention)!
It is kinda strange that there are two versions of this rotary. Actually, I think I would prefer the version that stops anyway. I just have a lot of the other kind.
wstimson
I got the same switch from Smallbear for the Wavelord and mine also does not rotate all the way around continuously.  It still works just fine, but it took a bit to figure out which waves are which.  :)  I also spent a long time wondering if I ordered the wrong thing or was doing something wrong... glad it's not just me.  :)
