WaveLord Tremolo
Started by dawson, January 12, 2020, 01:29:05 AM
dawson
Here we have the Mad Bean WaveLord Tremolo:
This build came together quite nicely for a "noob/cowboy" like me- I'm impressed with the variety of waveforms and the tweakability available with the DIST. knob.
I've been messing around with these large 8mm diameter LED's and decided I'd wire LED 1, the bypass indicator, as a red 8mm, and LED 2, the pulse indicator, as two teal 3mm LED's mounted beneath the larger red one.  As you can see, in order to fit my fancy lights I had to turn the TAP footswitch 90* and under the PCB, which had to tilt a bit.  Anyhow, I couldn't get a great picture of the red LED but it looks really cool in person- it's switched OFF in the upper left photo and ON in the lower left.
Criticism is encouraged: constructive, or otherwise.
dan.schumaker
Looks awesome!  I like how you used the wave shapes on there, a good sneaky way to know what they are.
That's a great build!  Very crafty use of leds too, bet it looks pretty slick in action.
Caedarn
Very nicely done!  The enclosure graphics look great.
dawson
Thank for looking, guys!
Quote from: dan.schumaker on January 12, 2020, 01:52:42 AM
Yeah, usually I agonize for days over what/how the etch is going to look, but thanks to the key in the build document, these graphics pretty-much made themselves.
I DID make a mistake on the graphics.. the 6th waveform down on the right pulses 4 times between rests, but the graphic only shows 3, so keep that in mind if you too are building this project.
Great project from MadBean- very much looking forward to tap tempo phasers in a month or two!
simon
That looks great.  Is there a chance that you will post a sound clip?
dawson
Quote from: simon on January 28, 2020, 10:12:06 PM
Hi, Simon, I won't be posting sound clips any time soon- I haven't got the knowhow/gear together quite yet, but thank you for your interest- it will help spur me in that direction.
Looks amazing! Great job
Love the artwork also.
