Road Rage 2019 help with odd voltages
Started by selatape, January 13, 2020, 10:04:31 PM
selatape
Hi everyone,
Just built the 2019 version of the road rage with an LT1054 and 78L15 15v regulator for my prototyping board and I think my voltages might be a bit off.
With no load I'm getting:
+9.0v (unregulated +9v output)
+8.8v (regulated +9v output)
+13v (between D3 and D4)
+16.2v (+15v output)
+16.9v (+18v output)
-8.8v (-9v output)
My first thought is to swap the regulator out but any other ideas if/where I should start troubleshooting? I remove the regulator presumably I should get +/-18v if everything else is working? Though I would ask before I start ripping apart the circuit.
Thanks for you help.
Update: I went ahead and removed the regulator and now I get +17.5V (+18v output). Seems a bit more like it. Never heard of problems with regulators, but I'm going to breadbaord a few to check.
selatape
Feel pretty daft but I had the regulator the wrong way round. The blame lies squarely on the bad datasheet for this one, if it's the bottom view of a TO-92, write it next to the pin configuration so numpties like me will see it ;D.
I'm still getting just +16.9v from the "+18v output" when using the 15v regulator, if anyone else has built this, is that as good as I'm likely to get?
franblanc
ROAD RAGE 2019: I'm also getting 16.8 volts from the 18 volts output pads. I have 9.2 volts running into the charge pump from a DC PSU. I have C5 and C6 omitted on the Road Rage with C6 jumpered between positive and negative. I reflowed everything and checked all the grounds. Not sure where I lost that extra volt but I need it to kick start a Univibe clone. Do you have the correct voltage readings for the LT1054 pins? Maybe I have a bad IC.
