Rustbucket!
Started by jimilee, January 19, 2020, 07:15:13 PM
This is my Rustbucket. There are many like it, but this one is mine.
Went with kind of the same theme that many go with, just a different take.
dawson
Nice work,
That's a good look for the circuit- seems to have turned out very shiny, how do you like the sounds?
Now..not to draw attention away from the positive, but you don't get a dc jack looking like that without a tale to tell!
Criticism is encouraged: constructive, or otherwise.
Love it, such a great effect! I really like your take on the artwork.
Quote from: dawson on January 19, 2020, 09:00:14 PM
Nice work,
Yeah, I had a tear out on the jack.  I don't have use if my drill press right now, and I didn't think to use a clamp to hold on to it.
Quote from: Matmosphere on January 19, 2020, 09:36:03 PM
Thank you.
That graphic is cool, wish I's found it.  Build looks great!
dawson
Quote from: jimilee on January 19, 2020, 11:24:07 PM
Ah that's a bummer, I've totally done that before..with the wrist-twisting and the project flying across the room..your mileage may vary..but yeah, many times..
The upside, however, is that if anyone asks later, you can tell them something badass like you didn't have any bullets small enough that day.
Quote from: dawson on January 20, 2020, 12:06:58 AM
Bwahahahaha, I figured I'd get some JB weld or something I'd it came down to it. I broke a couple of drill bits  while using my drill press and that happened. It's kind of exciting. Especially if the enclosure catches your thumb on its way across the room.
Stomptown
Live the graphics Jimmilee! This reminds me that I need to buy an 18v adapter to see if all the ICs I replaced in mine actually did any good! Re: enclosures flying across the room: I haven't had that issue since I purchased a decent stepped drill bit.  It's a real game changer.  It makes hand drilling a breeze! Iirc I went with an Irwin and it's going strong after 2-3 years of abuse.
Quote from: Stomptown on January 20, 2020, 05:40:43 AM
No kidding? I bet you sooner have to change bits for the different holes too. How quickly do they wear out?
Quote from: jimilee on January 20, 2020, 02:11:05 PM
No kidding? I bet you don't have have to change bits for the different holes too. How quickly do they wear out?
Stomptown
One bit will cover everything in a pedal and I'm still waiting to see how long they take to wear out after 2-3 years.
Irwin Tools Unibit #1 1/8-Inch to 1/2-Inch Step-Drill Bit, 1/4-Inch Shank (10231) https://www.amazon.com/dp/B00004THYX/ref=cm_sw_r_cp_api_i_CAEjEb9AEY5XX
