Filter and Drive Dual Pedal Idea
Started by Bio77, February 08, 2020, 12:24:01 PM
I have a Flunkee (DOD FX-25 Envelope Filter) and a Runtime Error (Systech Overdrive) sitting in my queue.  Both are 1590A, which I'm not crazy about.  I was thinking of combining both circuits into one pedal.  Do you think these circuits would complement each other?  If so, what order is recommended or should I include an order selector switch?  Opinions welcome!
Willybomb
Filter then drive.  The filter will work best with an uncompressed signal.
Filter then drive with an order swapping switch.
I'd at least build the Runtime first and take a listen.  It's not at all a standard overdrive and tends to be pretty dominant in terms of an effect.  It's a bit of sonic bitch slap.
Then again it would be a filter extravaganza so it may be exactly what you're looking for.  YMMV.
Thanks Jimi and Willy, appreciate the input.
Quote from: gordo on February 08, 2020, 04:51:41 PM
Thats good advice, now that you said that.......It might not be that interesting to sweep across a frequency range if there's just one dominant frequency.  Probably sounds like a filtery volume swell.
It does sound really nice with a lite overdrive in front or behind and also sounds great with a compressor behind it.  I've been rebuilding a little Marshall DSL-401 that was a bit of a dumpster dive and got the little beast fired up after a lot of work. The Flunkee happened to be on the bench and an hour completely vanished as I fiddled around with both. Not a bad sound to be had between the two of them.
