Author Topic: Eagle help  (Read 502 times)
Guybrush
  • Electron Doctor
    • View Profile
Eagle help
« on: March 08, 2020, 10:03:16 AM »
Hi all
I've recently decided I'd like to get my head around Eagle. I've drawn a schematic up and have converted it to a board layout but I'm overwhelmed by the options Eagle gives you for things like trace widths, board layers, polygons, etc etc. I was just wondering if anyone knows of any good videos or online tutoruals that run through the basics of eagle for pedal makers?
I've had a good Google for help but I'm just getting lost in the sea of info out there.
Thanks as always!
benny_profane
  • Solder Ninja
    • View Profile
Re: Eagle help
« Reply #1 on: March 08, 2020, 11:09:44 AM »
Check out the JMK eagle tutorials from jkokura. Super comprehensive and massively helpful!
https://www.madbeanpedals.com/forum/index.php?topic=9661.0
Guybrush
  • Electron Doctor
    • View Profile
Re: Eagle help
« Reply #2 on: March 08, 2020, 01:14:47 PM »
Perfect! Thank you!
Guybrush
  • Electron Doctor
    • View Profile
Re: Eagle help
« Reply #3 on: March 08, 2020, 02:45:17 PM »
Me again.
Can anyone point me in the right direction of the most up to date MBP Eagle library? The one I have doesn't saeem to have working 9vt ir GND pads.
Also, the gaussmarkov library doesn't seem to be compatible with Eagle 9.5.2 Free (mpost recent version).  >:(
Thanks again
« Last Edit: March 08, 2020, 03:07:55 PM by Guybrush »
  • Electron Doctor
  • Josh
    • View Profile
    • 1776 effects
Re: Eagle help
« Reply #4 on: March 08, 2020, 03:26:50 PM »
If you're just getting started with ECAD I would recommend starting with KiCad and following the Contextual Electronics tutorials.
If you only have access to a newer version of Eagle it could be dead in the future and you will have to migrate to the Fusion360/ECAD mess.  Kicad is also free with no board size, layer, or pin count limitations.  Just my opinion though.
Josh
Guybrush
  • Electron Doctor
    • View Profile
Re: Eagle help
« Reply #5 on: March 08, 2020, 04:33:15 PM »
Ahh ok, thank you. I wasn't aware there were issues with Eagle. I'll check out Licad for sure. Hopefully I can import the schematic I spent a few hours drawing up in Eagle today  ::)
Thanks again
DLW
  • Solder Ninja
    • View Profile
Re: Eagle help
« Reply #6 on: March 08, 2020, 08:35:27 PM »
Me again.
Thanks again
You're better off naming the net that a generic pad is connected to. The V+, GND, etc pads from Gaussmarkov have a mind of their own sometimes.
DLW
  • Solder Ninja
    • View Profile
Re: Eagle help
« Reply #7 on: March 08, 2020, 08:38:25 PM »
You can also add a small net to any component and give it a name (e.g. Vb, Vcc, Vr, etc...). It's much easier than using the premade Gaussmarkov connections.
  • Electron Doctor
    • View Profile
    • http://alanp.info/
Re: Eagle help
« Reply #8 on: March 08, 2020, 09:59:13 PM »
Don't use Gaussmarkov.
The pads in that library are retardedly small, from memory.
imjonwain
  • Transistor Tickler
    • View Profile
Re: Eagle help
« Reply #9 on: March 15, 2020, 06:53:34 PM »
I use Eagle (and have for years) and am happy to help you but if you're learning from scratch go with Kicad.  I'm trying to switch over at the moment.  The Contextual electronics tutorials are great and the devs have a lot planned for the future of Kicad.
  • Electron Doctor
  • Felix - Graz, Austria
    • View Profile
    • My blog - in german
Re: Eagle help
« Reply #10 on: March 16, 2020, 11:28:38 AM »
Guybrush! Haven't seen you in ages, Welcome back!
I use eagle and Fusion 360 at work and I think it's actually a good combination and afaik, free eagle will still be available to hobbyists.
There's a whole sub-forum section dedicated to pcb layouts and Eagle in particular: https://www.madbeanpedals.com/forum/index.php?board=45.0
you can also find the most recent madbean library there. Jacob's tutorials still apply to most parts and were also my starting point. Since then, several features where added and altered, but it stayed true to its roots in most parts. I can also recommend putting in shortcuts for several commands, such as copy, move, route, ripup, adjusting visible layers etc.. This makes stuff much more comfortable and faster
My build docs
My etching tutorial
Guybrush
  • Electron Doctor
    • View Profile
Re: Eagle help
« Reply #11 on: March 17, 2020, 05:09:31 PM »
Hey man. Yeah been away for a while trying to do other things as well as building pedals  ;D
Thanks for the info, much appreciated. I will have a look at that sub forum now as I have another Eagle question.
I didn't realsie you could make shortcuts. Having to keep clicking copy/paste/delete etc is a real pain! Haha
Thanks everyone for their help. I'll check out Kicad as soon as I get chance.
