Rustbucket Help
Started by Vtguy22, March 15, 2020, 05:28:29 PM
Vtguy22
Hello,
  I am trying to debug my Rustbucket and am not having much luck.  The bypass seems to work fine, as does the blend.  No effect seems to be coming through though.  Below are my voltages and pics.  Any help would be appreciated.
IC1
1  0
2  0
3  0
4  -14.6
5  0
6  -1.8
7  .46
8  14.68
IC2
1  12.58
2  0
3  0
4  -14.6
5  -2.5
6  -1.8
7  14.68
8  12.20
IC3
1  0
2  0
3  0
4  -14.6
5  0
6  0
7  -.5
8  14.7
IC4
1  0
2  0
3  0
4  -14.6
5  0
6  0
7  .9
8  14.7
IC5
1  -7.3
2  -7.3
3  -7.3
4  0
5  0
6  0
7  -14.6
8  -14.6
9  -14.6
10  -7.2
11  -8.8
12  -14.6
13  -7.4
14  0
IC6
1  0
2  -7.1
3  -2.4
4  -13.5
5  -14.6
6  -8.8
7  -13.8
8  -13.8
IC7
1  0
2  14.5
3  0
4  0
5  0
6  1.8
7  0
8  0
9  0
10  0
11  0
12  0
13  14.55
14  14.55
IC8
1  0
2  0
3  14.4
4  0
5  0
6  1.8
7  0
8  0
9  0
10  0
11  0
12  14.5
13  0
14  14.5
IC9
1  0
2  0
3  0
4  -14.6
5  0
6  0
7  0
8  14.6
IC10
1  0
2  0
3  11.7
4  0
5  14.4
6  14.4
7  0
8  14.5
IC11
1  0
2  0
3  0
4  -14.6
5  -14.6
6  0
7  14.6
8  0
IC12
1  -14.2
2  0
3  0
4  -14.6
5  -14.4
6  0
7  14.7
8  0
IC13
1  5.09
2  0
3  -14.6
4  0
5  14.7
Q1
  .98
  1.3
  -2.5
Q2
  0
  -.5
  -1
Q3
  .88
  1.49
  .92
Q4
  .88
  1.48
  1.8
Q5
  0
  72mv
  -14.4
Q6
  .48
  0
  -5.2
Q7
  -14.6
  -14.6
  -14
Q8
  -14.6
  -14
  -14.6
Thank You,
Paul.
You need to re-flow that board first, I can see several cold joints.
Vtguy22
Thanks, did that, it behaves the same.
The above picture shows a missing a transistor, is it still missing.
Obviously Jimi's point is very important (nice catch!) but if it is installed, did your voltages change with the re-flow?
Vtguy22
Thanks, yup it was there for testing.
The voltage changes were small, here are the new values:
IC1
1  0
2  0
3  0
4  -14.6
5  0
6  -1.4
7  .52
8  14.68
IC2
1  12.58
2  0
3  0
4  -14.6
5  -2.5
6  -1.8
7  14.68
8  12.20
IC3
1  0
2  0
3  0
4  -14.6
5  0
6  0
7  -.5
8  14.7
IC4
1  0
2  0
3  0
4  -14.6
5  .44
6  .46
7  1.07
8  14.7
IC5
1  -7.3
2  -7.3
3  -7.3
4  0
5  0
6  0
7  -14.6
8  -14.6
9  -14.6
10  -7.2
11  -8.8
12  -14.6
13  -7.4
14  0
IC6
1  0
2  -7.1
3  -2.4
4  -13.5
5  -14.6
6  -8.8
7  -13.8
8  -13.8
IC7
1  0
2  14.5
3  0
4  0
5  0
6  2
7  0
8  0
9  0
10  0
11  0
12  0
13  14.55
14  14.55
IC8
1  0
2  0
3  14.4
4  0
5  0
6  2
7  0
8  0
9  0
10  0
11  0
12  14.5
13  0
14  14.5
IC9
1  0
2  0
3  0
4  -14.6
5  0
6  0
7  0
8  14.6
IC10
1  0
2  0
3  11.7
4  0
5  14.4
6  14.4
7  0
8  14.5
IC11
1  0
2  0
3  0
4  -14.6
5  -14.6
6  0
7  14.6
8  0
IC12
1  -14.2
2  0
3  0
4  -14.6
5  -14.4
6  0
7  14.7
8  0
IC13
1  5.09
2  0
3  -14.6
4  0
5  14.7
Q1
  .98
  1.3
  -2.5
Q2
  0
  -.5
  -1
Q3
  .88
  1.49
  .92
Q4
  .88
  1.48
  1.8
Q5
  0
  140mv
  -14.4
Q6
  .48
  -.5
  -6.3
Q7
  -14.6
  -14.6
  -14
Q8
  -14.6
  -14
  -14.6
