Vfe zener cap combination. I can’t see what’s going on there on both the Tractor Beam and Bumble Bee
Started by jimilee, April 26, 2020, 03:05:54 AM
Vfe zener cap combination. I can't see what's going on there on both the Tractor Beam and Bumble Bee. Is the cap just paralleled with the zener?
It's a cheap voltage regulator. The combination is used to make reference and bias voltages for the JFETs. You wouldn't want to use a resistor divider there because the supply voltage can fluctuate with battery life or different DC supplies. The parallel cap it to reduce noise on the VREF.
Here's some info you want to read more about zoners as voltage regulators.
