Author Topic: Zero Point Micro build docs / PDF?  (Read 1629 times)
mathias
  • Diode Destroyer
« on: June 01, 2020, 10:23:20 AM »
Hello,
First of all, my apologies if this is not the right forum to post this. I didnít want to add questions to the errata post for the Zero Point Micro PCB, and I couldnít find any other threads about the build docs.
I see the Zero Point build docs on the Archives page, but I was hoping that the Zero Point Micro had its own docs. I have 2 of these PCBs and want to build them up.
Thanks in advance!
  • Administrator
  • Brian
    • madbeanpedals
Re: Zero Point Micro build docs / PDF?
« Reply #1 on: June 01, 2020, 10:31:41 AM »
All the docs are actually in the Zero Point archive file.
electronarchy
  • Diode Destroyer
« Reply #2 on: December 06, 2021, 02:17:59 PM »
bump
Hi, I am looking for this too, a year later, and I can't find the archive file. Anyone have a link?
Trying to patch up an old ZP Micro I found lying around.
electronarchy
  • Diode Destroyer
  • Administrator
  • Brian
    • madbeanpedals
« Reply #4 on: December 06, 2021, 02:25:07 PM »
There's an archive section. Under the delay part you'll find a zip that has all the Zero Point documentation:
https://www.madbeanpedals.com/projects/archives/index.html
Direct link: https://www.madbeanpedals.com/projects/archives/Delay/ZeroPoint.zip
electronarchy
  • Diode Destroyer
« Reply #5 on: December 06, 2021, 03:42:36 PM »
thank you kindly sir bean! funny I have been brought back around here.... i built a couple of your pedals back in 2010.
now i'm patching up a dual pedal that has a hipster fuzz into a ZP Micro. my friend wants me to make it possible to get a full wet signal from the delay for extra spacey sounds. after looking at the schematic i think i'll try this: snip out r3, short r13 to c18 to bypass the mix pot, and then use the mix pot as a voltage divider between the fuzz and delay outputs
