Dual Drive Series/Parallel
Started by ogguitar, July 27, 2020, 03:03:21 AM
ogguitar
Hello all,
I'm doing a layout for a dual drive, and I'm hoping to have a switch that would allow for some routing choices. Each drive would have its own foot switch, but the toggle would select between 3 configurations for when both are activated
1) Drive A -> Drive B
2) Drive B -> Drive A
3) Parallel
I've been researching a fair bit yesterday and today, but I haven't found much out there. It's not so much "how to make this parallel" that I'm having trouble with, but "how can I have the option of running parallel or reversing order in series."
Cheers
I'm no expert but I would think this would be a little more complex than just a switch.  if you want to do them in parallel you'd need some kind of mixer to combine the signals at the output. It would probably require a small board and some thought about signal routing. I would say your best bet is to look at how to have them in parallel and work backward to figure out the switching.
Have you looked through AMZFX I'm guessing your answer might be there somewhere.
ogguitar
Quote from: Matmosphere on July 27, 2020, 07:42:21 AM
Yeah figured this would end up being the case, but not sure what the workaround would be. Will check out AMZFX thanks!
ogguitar
Quote from: jimilee on July 27, 2020, 08:48:37 AM
Interesting article
http://www.generalguitargadgets.com/effects-projects/boosters/parallelyzer/
Also this if Diablochris has anymore
https://drive.google.com/drive/folders/0B7QeV_7r70dTUjdzWXBtdUF1aUU
Had read a mention of diablochris in another thread but couldn't get any results from searches. Cheers!
diablochris6
Quote from: ogguitar on July 27, 2020, 09:33:38 AM
I'm right here.
ogguitar
I think I figured out how to wire the 3 way toggle switch, or at least one possible way. I've attached an image for anyone interested. Red goes to and from circuit A, Blue goes to and from circuit B. Green is a bridge. Orange/gold goes from input jack and to output jack (or blending circuit if needed). So with the 4PDT it's possible to get A->B at position 1, A+B at middle position, and B->A at position 3.
I'm pretty sure it should be possible to just connect the wires from 1 and 6 to 9 and 10, respectively. The way I drew it though helped me visualize the flow a little better. I guess the main thing now will be seeing what the circuits I'm using will need to work in parallel.
