Author Topic: Mimir's Well build  (Read 498 times)
  • Electron Doctor
    • View Profile
    • Project Website
Mimir's Well build
« on: June 11, 2020, 02:48:54 PM »
This is too much fun.  I bought the board from MAS-Effects and it was kitted with the TFT display, Arduino Nano, and banks of patches.  Cutting up the box wasn't too bad.  I used a dremel and then cleaned up the edges with a file.  MAS supplied the vinyl decal as well.
Think of it as 4xFV-1's with a display showing the patch name (or bypass) and what each of the knobs do.  Given the complexity of the project it was a pretty easy build.  I added a PedalPCB bypass.  I like the momentary function and it's a LED-to-ground switch as opposed to most other bypass' (including mine).
I, of course, didn't have the right switch so am waiting for a delivery from Lawrence over at LMS as well as some proper knobs.  Since I'll have to pull the guts to add the switch I'm thinking I'll add a clock board to replace the crystal and make the clock an external knob.  I picked the Tayda "matte violet" enclosure because, well, it's matte violet.  Real Mimirs' are either black or white.
I'll update photos when it's complete but here's what I have so far.  And yes, I cleaned the flux schmootz off the board around the rotary switch.  And yes, the display is sunken at the top left a tad.  It'll get anchored when I finish it.
On lockdown outside of Chicago
  • Electron Doctor
  • Eric K.
    • View Profile
Re: Mimir's Well build
« Reply #1 on: June 11, 2020, 02:59:37 PM »
Thank you!  ;)
Nice build!
  • Global Moderator
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #2 on: June 11, 2020, 04:04:55 PM »
Man, what an awesome effect. 89.00 isn't bad for the DIY version. I might need to have one.
  • Electron Doctor
  • Stephan Nelson / New Zealand / Aotearoa
    • View Profile
« Reply #3 on: June 11, 2020, 04:26:35 PM »
Super build, exciting stuff!
What's the advantage to make the clock board tweakable with external knob?
Can you compare the sounds and quality of sounds to other FV-1 things you might have built and heard?
Cheers!
  • Electron Doctor
  • Corey - Christchurch, NZ
    • View Profile
    • Soundcloud
« Reply #4 on: June 11, 2020, 06:12:40 PM »
Impressive gordo, cool project and excellent execution 8)
