Zero point mini compatible with 3PDT-01 PCB?
Started by smallpoxchampion, June 15, 2020, 10:42:00 AM
smallpoxchampion
Was wondering if these two boards are compatible, Do I need to make any connections from the ZP PCB to the 3PDT PCB or can I just wire the LED to ONLY the ZP PCB? I noticed this version doesn't have an L pad or is that the same thing as ground?
Yep, just wire the led where you want.
smallpoxchampion
#2
Got it wired up with the led going only to the ZP PCB, it turns on when I power it but will not turn off when I click the 3pdt. There is an open ground pad on the 3pdt PCB, do I just need to connect that to any ground point? The two ground pads on the ZP PCB are connected, one is to the negative terminal on my DC jack and the other is going to the cathode of the LED. Also the effect is total noise when I click the 3pdt. I know I've got my grounds screwed up somewhere. Sorry for the noobness of this post.
smallpoxchampion
Resolved! Used the non-madbean wiring diagram for the breakout board and it fired right up!
