What the hell are these called?
Started by madbean, August 06, 2020, 05:57:02 AM
The little grounding springs for PCB to enclosure. I have some, I just can't remember where I got them or what they are actually called.
Ah okay, they are just battery contacts. Had a senior moment.
For the ones that are not just repurposed battery contacts, I believe they are called "grounding contacts". Battery contacts are probably more plentiful and cheaper though.
 "Solderless negative electron pathway constructor bridge" or "doohickey" for short.
Yep. I clicked the, "continue without supporting us" link....
Some common terms are "Whatchamacallit", "Thingameebob" or, in extremity, "F---ing bl---- piece of g------ sh--."
I believe the technical term is a Faflapathong
I found a cheap alternative. Not the sturdiest piece of kit but should work for what I'm needing.
https://www.mouser.com/ProductDetail/534-243
When I change my guitar strings, I have a few of those lying around afterward.  I've always just thrown them away, but now I know they are worth $0.10 apiece.
benny_profane
Quote from: EBK on August 06, 2020, 08:46:29 AM
Oh man that is a clever idea!
You use too many wraps, then!
;D
