Pangea Vibe external speed LED
Started by holm, September 03, 2020, 07:32:14 AM
holm
Hello
I'm about to start building the Pangea Vibe, and was wondering where to insert an external LED for the speed control, can't find it in the document?
In advance thanks
Erik
danfrank
Attaching a schematic would help...
On many other modulation pedals, the output of the LFO is where you would attach the resistor/LED. Super bright green LEDs work well because they usually light up strongly with less than 1ma of current. You don't want to "weigh down" the LFO output with a LED that uses a lot of current.
holm
Looks like D3 on the LFO schematic is an LED that will pulse in time with the effect, is that what you need?
danfrank
#4
 Yes, D3 will pulse with the speed of the vactrol LEDs. This circuit is similar to the MBP Glass Hole in this respect.
This is an interesting circuit with the 8038 IC
It's a fab sounding circuit too! I found it important to use the same type and brand LED for the indicator LED and the vatcrol LEDs by the way. If you use a different colour LED for indicator it might affect the way the LEDs for LDRs behave.
holm
Thank you gentlemen, I'll give it a go.
/Erik
Let me add to what Cooder correctly stated--you'll want clear yellow tint (not the foggy diffused) LEDs. I got some from Mouser that were 2300mcd if I remember correctly. Having stronger ones like this will also help make sure the tremolo is loud enough in comparison to the vibe/chorus effect.
holm
Thanks
I'll keep that in mind, I got the kit from musikding, and I do not know the intensity of the LEDs provided with the kit. So the brighter ones also sounds better?
\Erik
I think if the LEDs that make the vibe and trem are not bright enough, the pedal will sound kind of weak and low-output. If yours are part of a kit, they probably included ones that will work correctly.
